English
Error: forrtl: severe (38): error during write, unit 0, file, CONOUT$
Error Message
This Windows error occurs when attempting to print from ArcView 3.2, using 'ArcView GIS to ArcPress for ARC/INFO' extension and ArcPress for ArcGIS 8.1:
Cause
The extension is not compatible with ArcPress for ArcInfo 8.1.
Solution or Workaround
  1. Export the layout from ArcView 3.2 as a PostScript file.
  2. Run ArcView for ArcGIS 8.1 from the Start menu and print the PostScript file.
    A. Click Start > Programs > ArcGIS > ArcInfo Workstation > Print.
    B. Select the desired file, navigate to it if necessary.
    C. Select ArcPress as the Driver.
    D. Click Print.
    E. Select the printer and device.
    F. Click OK.
    Don't use the extension in this case.
