English
Error: The UML package representing the workspace could not be found in the model
Error Message
The Schema Wizard stops with this message:
The UML package representing the workspace could not be found in the model.
Cause
There are two possible causes for this error:
· There is no package stereotyped as Workspace in the model.
· SQL Server 2000 has been installed in the same PC.
A UML package stereotyped as Workspace should be present in the model. This package is considered the root of the object model.
Solution or Workaround
Depending on what cause applies to your case, do one of the following:
  • Verify the UML model has a package stereotyped as Workspace.
  • Consult Microsoft's Knowledge Base for steps on resolving this problem. See the link in the Related Information section below.
Related Information
