HOW TO
ArcInfo shadesets contain fill patterns and colors. ArcView uses the pattern information when the shadeset is loaded into a fill palette, however, the color information is not used. If a colormap is created from the shadeset in ArcInfo, it is possible to use an Avenue script to convert the colors in the colormap to an ArcView color palette.
Code: f = FileDialog.Show ("*", "All Files", "Select ColorMap") If (f = nil) Then Return nil End lf = linefile.Make(f.Getname.asFileName, #FILE_PERM_READ) lf.GoToEnd TheEnd = lf.Getpos lf.setpos(2) cList = {} for each l in 2 .. TheEnd valList = lf.ReadElt If ((valList = nil) or (valList = "")) Then Break End c = Color.Make r = valList.asList.Get(1).asNumber g = valList.asList.Get(2).asNumber b = valList.asList.Get(3).asNumber c.setRGBlist({r,g,b}) cList.add(c) End aPalette = Palette.Make aPalette.SetList (#PALETTE_LIST_COLOR, SymbolList.FromList(cList)) fnew = FileDialog.Put ("colormap.avp".asFileName, "avp", "Save Color Palette") If (fnew = nil) Then Return nil End aPalette.SaveToFile (#PALETTE_LIST_COLOR, fnew)
Get help from ArcGIS experts
Download the Esri Support App
