English
Problem: The measure tools return incorrect value
Scale and distance are not correct even though the view's map units are set properly.
Cause
ArcView has incorrectly calibrated the screen resolution.
Solution or Workaround
Calibrate your screen resolution. Refer to the ArcView Help document "Calibrate the Screen."
Related Information
