ERROR
Get a Search Error error message when using Find on a joined layer from the table window
Error Message
This problem is addressed in ArcGIS 8.1 Service Pack 1. See the Related Information section to download this pack.
When I perform a join and then use the Find tool, I get the following error:
Search Error
Cause
This problem only happens when joining data from different data sources, for example, joining a dBASE file to a Personal Geodatabase layer. In this case, the different data sources are not taken into account when the find is performed.
Solution or Workaround
Close and reopen the table window. The find tool will now work properly.
Article ID:000004008
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
