English
Error: Error 1308. Source file not found
Error Message
When installing ArcInfo Workstation, the following error message is displayed:
"Error 1308. Source file not found:
<install_source>:\\arcgis\arcexe8x\bin\griddespeckle.exe. Verify that the file exists and that you can access it."
Cause
When installing ArcInfo Workstation from a shared CD-ROM or network install source, the error occurs in place of the 'Please insert Disc 2' message.
Solution or Workaround
Remove Disc 1 and insert Disc 2 in the shared CD drive and then click Retry, and the installation continues and finishes.
