PROBLEM
This problem is addressed in ArcGIS 8.1 Service Pack 1. See the Related Information section to download this pack.
A TableView object may be embedded in a window from an application that is outside ArcMap and ArcCatalog. For example, a TableView can be placed inside a Visual Basic form.
The application will crash if you try to use any of the context menus in the TableView.
Some of the commands in these context menus require accessing the ArcMap or ArcCatalog Application object.
Get help from ArcGIS experts
Download the Esri Support App
