ERROR
The feature is on a network resource that is unavailable
Error Message
When starting ArcMap or ArcCatalog as a Windows user without administrative privileges, ArcMap or ArcCatalog returns the following error:
"The feature you are trying to use is on a network resource that is unavailable
Click OK to try again, or enter an alternate path to a folder containing the installation package 'ArcMap_vba.msi' in
the box below.
Use feature from:
<drive>:\arcexe8x\support\vba6"
Cause
Unknown
Solution or Workaround
  1. Create the directory that the error requests.
  2. Copy the \support folder from the ArcInfo Desktop disc into the directory created in Step 1.
  3. Use the Browse option in the error to browse to the requsted .msi. In this example the .msi is: <drive>:\arcexe8x\support\vba6\arcmap_vba.msi. Select OK.
Article ID:000003984
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
