English
How To: MERGE adjacent polygons in ArcEdit and control the attributes of the new feature
Summary
The ArcEdit MERGE command can be used in two different ways to combine adjacent coverage polygons into one new polygon and specify the attributes for the new feature.
Procedure
  • Method 1
    Merge two polygons and maintain the attributes from the polygon that is selected last.
    1) In ArcEdit, specify the edit coverage, edit feature and draw environment.
    Code:
    Arc: arcedit
    Arcedit: display 9999
    Arcedit: edit states polygon
    Arcedit: drawenvironment polygon
    Arcedit: draw
    2) Issue the MERGE command with no features selected.
    Code:
    Arcedit: merge
    3) When prompted, select the two adjacent polygons. The new polygon will have the attributes of the second polygon selected.
    Code:
    Select the polygon to be merged
    Polygon 65 User-ID: 22 Symbol: 14
    Select the polygon to merge into
    Polygon 64 User-ID: 24 Symbol: 14
    Merged 2 polygon(s) into 1
    In this example, Nevada was merged with California.
    Code:
    Arcedit: list
    136
    AREA = 71.42214
    PERIMETER = 43.45821
    STATES# = 0
    STATES-ID = 24
    STATENAME = California
  • Method 2
    Merge two or more polygons and specify the input polygon attributes which will be mainatined.
    Code:
    Arc: arcedit
    Arcedit: draw
    2) Select the polygon which you want to merge with other features but want to maintain the attributes for in the new feature.
    Code:
    Arcedit: select
    Point to the feature to select
    Enter point
    Polygon 35 User-ID: 1 Symbol: 14
    1 element(s) now selected
    Arcedit: list
    35
    AREA = 20.67119
    PERIMETER = 32.48690
    STATES# = 35
    STATES-ID = 1
    STATENAME = Washington
    3) Issue the NEW command to store the selected features attributes into memory.
    Code:
    Arcedit: new
    4) Select the adjacent polygons to be merged into one feature. In this example, Oregon, Washington and California will be merged.
    Code:
    Arcedit: select many
    1 = Select 3 = Who 9 = Quit
    Polygon 46 User-ID: 11 Symbol: 14
    3 element(s) now selected
    Arcedit: list
    35
    AREA = 20.67119
    STATES# = 35
    STATES-ID = 1
    46
    AREA = 28.18703
    PERIMETER = 24.78668
    STATES# = 46
    STATES-ID = 11
    STATENAME = Oregon
    64
    AREA = 41.45291
    PERIMETER = 39.23602
    STATES# = 64
    STATES-ID = 24
    5) Use MERGE with the SELECT option to merge the selected polygons. The new feature will have the attributes stored in memory from the NEW command.
    Code:
    Arcedit: merge select
    Merged 3 polygon(s) into 1
    Arcedit: list
    136
    AREA = 90.31113
    PERIMETER = 74.11569
    STATES# = 0
    STATES-ID = 1
