ERROR
Unable to write tagged value to repository
Error Message
This error occurs in ArcCatalog's Schema Wizard:
"Unable to write tagged value to repository"
Cause
Microsoft Access Repository file is set to Read Only.
Solution or Workaround
  1. Use Windows Explorer to navigate to the location of the repository file.
  2. Right-click the file and select Properties.
  3. On the General tab, uncheck the Read Only attribute.
Article ID:000003971
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
