English
Error: Assertion recmapfile failed at line 1182 "../vtab/vtab.c"
Error Message
This error occurs while creating a new shapefile, or editing an existing one:
Cause
The HOME environment variable references a read-only network directory.
Solution or Workaround
Set the HOME environment variable to a local drive that is not read-only.
For help with setting a system environment variable, see: How To: Edit an environment variable.
