PROBLEM
Subtype field defaults are not applied when changing subtypes using the table window
This problem is addressed in ArcGIS 8.1 Service Pack 1. See the Related Information section to download this pack.
This problem occurs when editing data from a geodatabase where there are subtypes defined.
When changing a subtype for a row using the Attributes dialog box, defaults defined in the subtype are applied. If you use the table window to change the subtype, the defaults are not applied.
Solution or Workaround
If possible, use the Attributes dialog box to change the subtype. Otherwise, the appropriate defaults will not be applied.
Article ID:000003967
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
