PROBLEM
Sometimes features from ArcIMS services do not get drawn or cannot be queried
Previewing, drawing, or querying features may unpredictably stop working.
Cause
The service uses data that is stored in ArcSDE. If the data was loaded into ArcSDE using the command line instead of ArcCatalog, the resulting layers may not have been correctly registered in the database. These layers do not have the ROWID or the OBJECTID columns.
Solution or Workaround
Register the ArcSDE layer:
Code:
sdetable -o register -c objectid -C ArcSDE -u username -p password -t tablename
For more information, see the ArcSDE Administration Guide, page 144.
Article ID:000003931
Software:
  • Legacy Products
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
