PROBLEM
The following behaviors with image/feature services may be experienced:
· Cannot perform find, identify, or select operations
· Cannot open attribute table
· Image is not downloaded
· Requested features do not draw. This error message will occur: "One or more layers failed to draw: You are not authorized to make this kind of request."
When you create a service in ArcIMS, you can set constraints on the server (access restrictions). These constraints can cause clients who do not have permission to experience these problems.
Get help from ArcGIS experts
Download the Esri Support App
