English
Problem: VBA procedures do not appear in Macro dialog box
In ArcMap, trying to run a VBA procedure using Tools > Macros > Macros, but the procedure does not appear in the list.
Cause
Procedures defined as private can not be run as macros.
Solution or Workaround
Define the procedure as Public.
Code:
Public Sub TestMacro()
MsgBox "This Macro Runs from the dialog"
End Sub
