PROBLEM
There a gap in the unique values legend for a raster when created programatically
After defining a customized unique value renderer, then removing a class from this renderer and applying it to a raster layer, a gap appears in the legend.
Cause
The RasterRenderer’s Update method does not refresh after removing a class from the renderer.
Solution or Workaround
When creating the renderer, add only the classes you are using. If you add all classes to the renderer, and then remove the unused ones, you will get a gap in the legend.
Article ID:000003850
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
