English
Problem: ArcMap quits when changing layer symbology
Changing the symbology for a layer causes ArcMap to quit without an error message.
Cause
This is a known issue with ArcMap.
Solution or Workaround
Uncheck the Environmental style in the Symbol Selector dialog.
[O-Image] Symbol Selector dialog box
The problem occurs when using the Environmental style in combination with other styles. The Environmental style can still be used by itself.
