English
How To: Edit measure (M) values with the Field Calculator
Summary
Use the ArcMap Field Calculator to calculate the measure values for the geometry of a polyline feature.
Procedure
Familiarity with the ArcObjects Geometry system is required before attempting this method of setting M values.
  1. Start editing a polyline feature class.
  2. Select one or more features.
  3. Open the feature class attribute table.
  4. Right-click the SHAPE field and select Calculate Values.
  5. In the Field Calculator, check the Advanced check box.
  6. Enter the VBA expression
dim pms as imsegmentation
set pms = [Shape]
pms.setandinterpolatemsbetween 0,100
dim pg as igeometry
set pg = pms
The example shows how to calculate the M values to range between 0 and 100 for a selected set of polylines.
[O-Image] Field Calculator - Calc Ms with values
This example shows how to calculate the M values to range between the values stored in two items for a selected set of polylines.
[O-Image] Field Calculator - Calc Ms with items
It is also possible to edit the M values for a polyline feature by using the Edit Sketch Properties dialog. See the Related Link below.
Related Information
