ERROR
Assertion: "project has filename" failed at line 1581 of file"../appl/project.c"
Last Published: April 26, 2020
Error Message
This error occurs when clicking the Make Default button on the Customize dialog box:
Assertion: "Project has filename" failed at line 1581 of file"../appl/project.c"
Cause
Your system doesn't have the $HOME environment variable defined.
Solution or Workaround
Create a $HOME environment variable.
For help with setting a system environment variable, see: How To: Edit an environment variable.
If ArcView cannot find a $HOME variable on your system, it will use the $TEMP variable instead.
Article ID:000003833
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
