HOW TO
Determine if a region subclass has overlapping features
Summary
This document shows how to determine if a region subclass has overlapping features.
Procedure
This example uses a coverage called CLEANEDCOV, which contains a region subclass called TEMP.
  1. Use REGIONPOLYCOUNT to create an INFO file that lists the number of region features that overlap each polygon.
    Code:
    Usage: REGIONPOLYCOUNT <in_cover> <out_info_table>
    {$ALL|subclass...subclass}
    Arc: REGIONPOLYCOUNT cleanedcov overlaps.frq temp
  2. Start Tables, select the INFO file created by REGIONPOLYCOUNT, and use LIST to display item values for the selected records.
    Code:
    Arc: TABLES
    Tables: SELECT overlaps.frq
    Tables: LIST
    Record POLY# TOTAL TEMP
    1 1 0 0
    2 2 1 1
    3 3 2 2
    4 4 1 1
  3. RESELECT records where TOTAL > 1 to find polygons that are part of multiple region features.
    Code:
    Tables: RESELECT TOTAL > 1
    1 Records Selected.
    Tables: LIST
    3 3 2 2
    The polygon with an internal number = 3 is part of 2 region features in the TEMP subclass.
Article ID:000003789
Software:
  • Legacy Products
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
