English
How To: Calculate the Soundex value for a street name
Summary
The Soundex function produces index values for English language strings. These values can be used to search for phonetically similar strings within a dataset.
ArcGIS uses an implementation of the Soundex function to index street names for geocoding services.
Procedure
The Soundex function used in ArcGIS produces a single character followed by three digits. It is calculated using the following procedure:
  1. The first letter of the street name is retained, and all occurrences of a, e, h, i, o, u, w, and y in the remainder of the street name are dropped. For example:
       Brookside
    Brksd
  2. Digits are added to the Soundex value for up to the first three remaining letters according to the following table:
    [O-Image] Soundex values
    In the above example:
       Brksd
    B622
    Ignore spaces if the street name contains multiple words.
  3. If fewer than three letters remain in the street name, trailing zeros are added to produce a Soundex value that is a single character followed by three digits. For example:
       Vine
    Vn
    V500
