HOW TO
Enable metadata editor tools
Summary
If the metadata tab for a dataset is empty or the metadata editing tools are disabled in ArcCatalog, you can enable them using the following steps in ArcCatalog.
Procedure
  1. Click the Tools menu.
  2. Select Options.
  3. Click the Metadata tab
  4. Make sure all the fields are filled out correctly and both check boxes are checked.
  5. Click OK.
Article ID:000003762
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
