PROBLEM
Interactive selection does not adhere to group layer drawing status in ArcMap
The Select Feature tool should not select features that are not visible. Turning off drawing for group layers does not disable Select Feature tool functionality.
Cause
This is a known issue.
Solution or Workaround
This issue has been addressed in ArcGIS Version 8.1.2.
Article ID:000003758
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
