PROBLEM
Steepest path on a TIN can return incorrect result in some cases
This problem is addressed in ArcGIS 8.1 Service Pack 1. See the Related Information section to download this pack.
Occasionally, a steepest path can terminate in an odd fashion. The path will go one way, then backtrack on itself along a concave triangle edge.
Cause
This is a known issue.
Solution or Workaround
    Article ID:000003746
    Software:
    • ArcMap 8 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
