PROBLEM
'Output Image Quality' slider bar on 'Page Setup' dialog box in ArcScene has no effect
Adjusting the 'Output Image Quality' slider bar on the 'Page Setup' dialog box in ArcScene does not affect the printing speed or quality.
Cause
This is a known issue.
Solution or Workaround
Export the Scene as an image. Use ArcMap adjust printing characteristics.
  1. Select File > Export Scene > 2D.
  2. Select an image format and specify a name on the Scene Export dialog box.
  3. Click OK.
  4. Add the the image to ArcMap.
  5. Print the image. Use ArcMap's printing options to adjust printing quality and speed.
Article ID:000003742
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
