PROBLEM
Getting to Know ArcView starts then stops
The Getting to Know ArcView (GTKAV) application runs for a few seconds after starting and then shuts down.
Cause
Possible conflict with default.apr files from another version of ArcView.
Solution or Workaround
  1. Click Start > Find > Files or Folders.
  2. Search for default.apr.
  3. If you find additional user default.apr files, rename them to default.bak
    Warning:
    Do not rename, move, or delete the default.apr in the AV_GIS30\Arcview\ETC directory
  4. Start GTKAV again. It should run without a problem.
Article ID:000003736
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
