English
Error: Fatal error can not open argument file argrcb
Error Message
Starting Arc after logging into Novell returns:
"Fatal error can not open argument file argrcb
program failed to start or was killed can not delete argument file, argexe"
Cause
There are conflicts with parameters in the Novell startup script.
Solution or Workaround
Edit your Novell login script and add the following:
Code:
DOS SET USERID="%LOGIN_NAME"
DOS SET USERNAME="%LOGIN_NAME"
DOS SET HDIR="F:\\"
