PROBLEM
** Fixed in ArcGIS 8.2**
Configuration keywords can be defined in the UML model by setting a tagged value. The configuration keywords are not being read by the Schema Wizard.
This is a known problem.
Set the configuration keywords while running the Schema Wizard.
Get help from ArcGIS experts
Download the Esri Support App
