PROBLEM
Raster selections are not retained after turning on and off
After selecting rows in a raster attribute table, and turning the layer on and off, the selection is retained in the table but the display is not refreshed.
Cause
This is a known issue with ArcGIS 8.1.
Solution or Workaround
Either of these workarounds will refresh the display:
  • Click the Refresh View button at the bottom of ArcMap's display.
  • Right-click the layer in the Table of Contents and select Zoom to Layer.
Article ID:000003720
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
