PROBLEM
Opening a new map file does not clear the transformation from the georeferencing session
** Fixed at ArcGIS 8.2 **
After clicking 'Fit to display' on the Georeferencing toolbar, and adding some control points, clicking 'New Map File' does not clear the transformation from the Georeferencing session. When the raster is re-added to ArcMap, the transformation is still applied.
Cause
This is a known limitation in ArcGIS 8.1.
Solution or Workaround
Click 'Reset Transformation' on the Georeferencing toolbar before clicking 'New Map File.'
Alternatively, exit and restart ArcMap to clear the transformation.
Article ID:000003717
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
