HOW TO
Rotate features in a shapefile theme around a user selected point
Summary
This article describes how to add to the View GUI a tool that rotates features within a shapefile.
Procedure
  1. Open three new script windows.
    A. Activate the Project window.
    B. Click the Scripts icon.
    C. Click New.
  2. Rename the scripts as follows.
    A. Select Properties from the Script menu.
    B. Type in a new name in the Name field.
    C. Click OK.
    RotateShapeApply.ave
    RotateShapeClick.ave
    RotateShapeUpdate.ave
  3. Paste each of the following scripts into the corresponding script window.
    Code:
    '-- Script: RotateShapeApply.ave
    '-- Determine the selected features
    theView = av.GetActiveDoc
    theTheme = theView.GetEditableTheme
    theFTab = theTheme.GetFTab
    fldShape = theFTab.FindField("Shape")
    theSel = theFTab.GetSelection
    '-- Set the rotation angle
    rotAngle = System.GetEnvVar("Angle").AsNumber
    if (System.IsShiftKeyDown.Not) then
    rotAngle = -1 * rotAngle
    end
    '-- Get the centre of rotation from the mouse click
    rotPt = theView.GetDisplay.ReturnUserPoint
    xs = rotPt.GetX
    ys = rotPt.GetY
    '-- If the theme is a polyline or polygon theme...
    '-- Rotate the selected shapes
    if ((fldShape.GetType = #FIELD_SHAPELINE) or
    (fldShape.GetType = #FIELD_SHAPEPOLY))
    then
    if (theFTab.StartEditingWithRecovery) then
    for each r in theSel
    shpIn = theFTab.ReturnValue(fldShape,r)
    lstPoints = shpIn.AsList.Get(0)
    newPoints = List.Make
    for each pt in lstPoints
    x1 = pt.GetX - xs
    y1 = pt.Gety - ys
    a1 = (y1 / x1).Atan
    c = y1 / (a1.Sin)
    a2 = (rotAngle * 0.01745329) + a1
    x2 = a2.Cos * c
    y2 = a2.Sin * c
    xf = xs + x2
    yf = ys + y2
    newPt = Point.Make(xf,yf)
    newPoints.Add(newPt)
    end
    if (shpIn.Is(Polygon)) then
    shpOut = Polygon.Make({newPoints})
    elseif (shpIn.Is(Polyline)) then
    shpOut = Polyline.Make({newPoints})
    else
    exit
    end
    shpOut.Clean
    theFTab.SetValue(fldShape,r,shpOut)
    theFTab.EndTransaction
    end
    theView.SetSelectMode(#GRAPHICS_SELECT_NORMAL)
    theTheme.Invalidate(True)
    end
    end
    if (fldShape.GetType = #FIELD_SHAPEPOINT)
    then
    pt = shpIn
    x1 = pt.GetX - xs
    y1 = pt.Gety - ys
    a1 = (y1 / x1).Atan
    c = y1 / (a1.Sin)
    x2 = a2.Cos * c
    y2 = a2.Sin * c
    xf = xs + x2
    yf = ys + y2
    shpOut = newPt
    end
    end
    '-- End of script: RotateShapeApply.ave
    Code:
    '-- Script: RotateShapeClick.ave
    if (rotAngle = nil) then
    rotAngle = "0"
    end
    response = msgBox.Input("Enter rotation angle", "Rotate Shape",rotAngle)
    if (response = nil) then
    exit
    else
    System.SetEnvVar("Angle",response)
    end
    '-- End of Script: RotateShapeClick.ave
    Code:
    '-- Script: RotateShapeUpdate.ave
    theTheme = av.GetActiveDoc.GetEditableTheme
    if (theTheme = nil) then
    selCount = 0
    else
    selCount = theTheme.GetFTab.GetSelection.Count
    end
    SELF.SetEnabled(selCount > 0)
    '-- End of script: RotateShapeUpdate.ave
  4. Make each script active and select Compile from the Script menu or click the
    [O-Image] Script compile button
    button.
  5. Switch to the Project window and select Customize from the Project menu.
  6. Select View from the Type dropdown list and Tools from the Category dropdown list.
  7. Scroll to the far right of the Model tool bar and click the last tool.
  8. Click the Separator button and then the Tool button.
  9. Make the following settings:
        Apply: RotateShapeApply.ave
    Click: RotateShapeClick.ave
    Cursor: Cursors.Bullseye
    Disabled: true
    Icon: Switch Select
    Invisible: False
    Update: RotateShapeUpdate.ave
    [O-Image] Rotate Shapefile New tool image.
  10. Close the Customize dialog box and open the view.
  11. Make the shapefile theme active and select Start Editing from the Theme menu.
  12. Select the features you wish to rotate.
  13. Click the new tool and then click a point on the view.
    The script uses this point as the axis of rotation.
  14. Type in the angle to rotate the selected features and click OK.
Article ID:000003714
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
