PROBLEM
After saving edits to a shapefile or dBASE file, the table window shows that it still has indexes
When saving edits on a shapefile or a dBASE file, existing attribute indexes are deleted automatically. However,the fields in the table window are still marked as indexed.
Cause
The table window is not refreshing correctly.
Solution or Workaround
Remove and replace the data in ArcMap.
Article ID:000003700
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
