PROBLEM
Large XY event layer is slow to draw and identify features
When working with a large layer created from an XY event source, drawing speed and identify results are very slow.
Cause
The X and Y coordinate fields are not indexed. This slows down the queries on these fields.
Solution or Workaround
Add indexes to the X and Y fields for the point event table.
  1. Select the table in ArcCatalog and right-click to open the Table Properties dialog box.
  2. Click the Index tab.
  3. Add new indexes to the table for the X and Y fields.
    [O-Image] AC - create index
Article ID:000003695
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
