English
Error: Traceback Failure During Error Recovery
Error Message
Rpcserver.start fails with the following error message on AIX 4.3.x.
------------------- TRACEBACK -------------------------
Module "IPC " Message 1: file "err.c " line 453
Module "Event" Message -1: file "event.c " line 2735
Module "CBlok" Message -1: file "/av31src/arcview/avenue/cblok.c" line 1552
Module "Script" Message -1: file "/av31src/arcview/avenue/script.c" line 151
Module "Script" Message -1: file "/av31src/arcview/avenue/script.c" line 324
FATAL ERROR Failure during error recovery
Abort process
Cause
The nofiles option is set to -1.
According to the IBM documentation, settings any of the
variables in /etc/security/limits to -1 can lead that variable to grow without a
limit. Unfortunately, setting the nofiles option to -1 causes the
rpcserver.start to produce the traceback error message.
Solution or Workaround
Set nofiles to 2000.
