English
Error: ACCESS server encountered a segment violation
Error Message
This error occurs when running DBMSEXECUTE or DBMSCURSOR on an Access table:
"ACCESS server encountered a segment violation"
Cause
The Access table contains column types that ArcInfo cannot interpret, such as Memo, OLE Object, and Hyperlink.
Solution or Workaround
Try one of the following:
  • Remove the offending fields from the table you are querying.
  • Create a query that doesn't include these fields.
