ERROR
No update operation allowed without Unique Id
Error Message
Listing related items in an Access table produces:
No update operation allowed without Unique Id.
Cause
The Access table needs to have a primary key specified.
Solution or Workaround
Open the table in Access and specify the relate column as a primary key.
Open the table you wish to work with in design view and select the field you wish to designate as the primary key field. The unique index is created automatically.
[O-Image] Adding a primary key, unique index, to an Access table
Article ID:000003682
Software:
  • Legacy Products
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
