BUG
Datum transformations are not supported when editing
This problem is addressed in ArcGIS 8.1 Service Pack 1. See the Related Information section to download this pack.
When changing the data's coordinate system with a datum transformation set, the edited data jumps.
Cause
The datum transformation is not applied properly when converting the data back to the coordinate system of the database.
Workaround
Make sure that the coordinate systems of the layers and the data frame are using the same geographic coordinate systems (datums).
    Article ID:000003680
    Software:
    • ArcMap 8 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
