BUG
A custom datum transformation that includes changing the units doesn't work correctly
When creating a custom geographic (datum) transformation for two geographic coordinate systems that use different units, all of the data may not display.
Cause
An extent that uses the output units is used to find which features to display. If the data frame units are radians but the original data is in degrees, only a tiny subset of a world dataset is displayed.
Workaround
This problem is addressed in ArcGIS 8.1 Service Pack 1. See the Related Information section to download this pack.
    Article ID:000003678
    Software:
    • ArcMap 8 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
