PROBLEM
When I use the ActiveX connector with different locales, numbers are truncated.
You are using the ActiveX connector with locales that have different decimal separators like "."(periods) or ","(commas).
The Cdbl() function is capable of handling different decimal separators for different locales; if the correct decimal separator is not used, the numbers might get truncated and lead to undesirable results.
Get help from ArcGIS experts
Download the Esri Support App
