English
Error: The extension has not been activated
Error Message
When using an extension, ArcMap or ArcCatalog returns the following error:
"The extension has not been activated"
Cause
The referenced extension isn't activated.
Solution or Workaround
Activate the extension.
  1. Start ArcMap or ArcCatalog.
  2. Navigate to Tools > Extensions.
  3. Check the box next to the desired extensions.
    [O-image]Tools > Extensions
  4. Click Close.
Related Information
