ERROR
Library has no valid tiles for feature class
Error Message
When selecting a tile from a Library in the Add Theme dialog, I get the following error message:
"Error Library <name>.<ext> has no valid tiles for feature class..."
Cause
The path names of the Location field in the INFO table are relative or contain symbolic links.
Solution or Workaround
Absolute path names should be used and symbolic links removed from the Location field in the INDEX.PAT file.
  1. Open the INFO table in ArcView.
  2. Select Start Editing from the Table menu.
  3. Remove the symbolic links and relative path names from the Location field in the INDEX.PAT file.
    Since Environment Variables are supported in the Library Definition file and in the INDEX.PAT file, they can be used to represent part of the path to the tiles.
    For example, if the library is located at /disk1/esri/mylib/database, then you can substitute the variable $MYDIR for /disk1/esri. The Library Definition and the INDEX.PAT files now contain $MYDIR/mylib/database in their Location fields.
Article ID:000003668
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
