PROBLEM
When the Layout is displayed at a 1:1 ratio, what the screen calls an inch does not equal a measured inch on the screen.
All display calculations in ArcView use dots per inch of the screen.
Code:
System.SetScreenSize Inches(12.5@9.0)
To make this permanent, add the line of code to the $AVHOME\etc\startup file.
Get help from ArcGIS experts
Download the Esri Support App
