PROBLEM
Scale text changes value when exporting or printing
The scale text is correct when viewing the layout in ArcMap, but it changes when printing or exporting the map.
Cause
This happens if the scale text element is not visible within the extent of the map window when the map is printed or exported.
Solution or Workaround
Make sure the Scale Text element is visible in the map window when exporting or printing: zoom to the full extent of the layout prior to exporting or printing.
Article ID:000003661
Software:
  • ArcMap 9 x
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
