ERROR
Stream in Progress
Error Message
This problem is addressed in ArcGIS 8.1 Service Pack 1. See Related Information section to download this pack.
Running the Integrate command against large feature datasets may return this message:
Stream in Progress
Cause
ArcMap is not releasing a small amount of memory for each feature processed in the Integrate operation. When processing a large number of features, ArcMap may run out of memory before the Integrate command can finish.
Solution or Workaround
To avoid this error:
  • Close any unnecessary programs to free additional memory before running the Integrate command.
  • Integrate smaller areas using the Visible Extent check box found under the Editing options > Topology Tab.
Article ID:000003653
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
