PROBLEM
Merging features after building an Edit Cache produces incorrect results
If features are selected prior to start editing and an edit cache is built, the Merge command may not merge the shapes of disjoint features together.
Solution or Workaround
Build the edit cache prior to selecting features. This will prevent the problem.
Article ID:000003647
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
