HOW TO
Use the PageManager Avenue class to set a layout's page size
Summary
The PageManager takes page size input from the user and matches the dimensions to the best available page size in the form of one of the page size enumerators.
Procedure
  1. Open a new script window.
    A. Activate the Project window.
    B. Click the Scripts icon.
    C. Click New.
  2. Paste the following code into the script window:
    Code:
    '-- Assumes that the active doc is a layout with included graphics
    aLayout=av.getactivedoc.getdisplay
    aPoint=Point.Make(7,10) 'the page size is 7 by 10 units
    aSize= aLayout.SetPageSize(aPoint)
    msgbox.info(aPoint.asstring,"The page size is:")
    aPage =aLayout.SetPageSize(aPoint)
    msgbox.info((PageManager.FindSize(aPoint).asstring),"The enumerator used is:")
  3. Select Compile from the Script menu or click the
    [O-Image] Script compile button
    button.
  4. Make the layout active.
  5. Select Run from the Script menu or click the
    [O-Image] Run compiled script button
    button.
Article ID:000003644
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
