English
Error: Finding if a field has alias/model name set. Field: Size
Error Message
When using CASE tools to create a class with a field named 'Area' in ArcSDE, the following error occurs:
"Finding if field has alias/model name set. Field: Size
ERROR ---> Invalid Argument"
Where ‘Size’ is the name of the field immediately before the Area field.
Cause
There is a conflict with SDE's internal Area field.
Solution or Workaround
Assign a different name to the Area field in the UML model.
