English
Error: Error (-9):Couldn't Start Server Task
Error Message
When sending a job to the Geoprocessing Server from ArcToolBox, an error occurs and the following message is written into the $ARCHOME/gpserver/etc/rqmgr.log file:
"Error (-9):Couldn't Start Server Task"
Cause
In order to connect to a remote processor ArcToolbox needs the username and password for the server. If the network password is changed, once the connection has been defined, sending a job to this connection will cause the error.
Solution or Workaround
  1. Delete the connection in ArcToolbox.
  2. Create a connection with the new password.
