English
Error: Unknown Object 'DwgSrc 1003' in Project
Error Message
This error occurs when attempting to load a layout:
Unknown Object "DwgSrc.1003" in Project "c:\$HOME\template.def"
Cause
The default template file references a CAD data source.
Solution or Workaround
There are two possible solutions to the eliminate the error.
  • Turn on the CAD reader.
  • Delete the template.def file from your $HOME directory.
