English
Problem: Measurements between layouts and views are vastly different
Measurements taken in the view don't match the measurements taken in the layout based on the scale bar.
Cause
There are two scenarios which may cause this problem.
  • The view contains data in a projected coordinate system, but the view's map units are set incorrectly. For example, the data projection uses feet but the view is set to meters.
  • The view contains data in the geographic coordinate system and the view's map units are correctly set to decimal degrees, but the view doesn't have a projection defined.
Solution or Workaround
Change the view properties map units or projection to the appropriate setting:
See: How To: Set a view's map units and projection
